How can we add numbers to sub-assemblies in CATIA to see them in balloons and bom list automatically in drawing?
By özgür kesebir on 08 Apr 10:26 13 answers 7 comments
I have an assembly with sub-assemblies and parts. And problem is that i just want to Generate numbers to only top components. But numbers only are added to the parts. If there is a sub-assembly CATIA does not add it a number. do anybody have an idea to add numbers only top parts and sub-assemblies?
  • Neil Meredith
    Neil Meredith over 3 years ago
    This is great, thanks! So with this I can generate an Advanced BOM that describes the sub-assemblies and not just the part recap.
    Now for the drawing annotation, is there a way to get the balloon tool to tag sub-assemblies instead of the sub-parts WITHOUT using ID numbers? (We tag part and assembly names directly instead of using key IDs. See my screenshot from before).
    Thanks for your help!
  • özgür kesebir
    özgür kesebir about 3 years ago
    You can try my .xml file. If the result is same, send me your .xml file.
    directory: C:\Program Files\Dassault Systemes\B21\intel_a\resources\standard\drafting
    dont forget my .xml file only suitable for V5R21 or higher
    e-mail:ozgur_kese1@hotmail.com
    ISO_ZGR.xml, 289 KB
    Download
  • Neil Meredith
    Neil Meredith about 3 years ago
    Thanks Ozgur, but I'm still getting the same behavior as before. Please see the files attached (I also emailed them to you as requested).
    BOM Test.zip, 229 KB
    Download
  • özgür kesebir
    Your .xml is working. i just check it. it is correct.
  • Neil Meredith
    Ah, OK. I think I didn't give enough detail in my question. I don't want to use CATIA generated "Item" numbers in the balloons, but instead use Part and Product names directly. It works fine for Parts, but there is no way to balloon a Sub-Assembly unless I use a text annotation with a leader instead of a balloon.
    See my screenshot above with the hardware sub-assembly "BOLT_ASB_05" called out for an example of what I'm trying to do.
  • SS
    SS about 2 years ago
    Thank You very much!
    You help me lot!!!!!
  • Utku Bayram
    Utku Bayram over 1 year ago
    Hi All
    Is that possible to Add "Components Sub Part" not "products sub parts" to Drawing BOM
    They are different Component and Product and Part
  • özgür kesebir
    özgür kesebir over 1 year ago
    Components mean in catia is grouping part or assemblies. so you can not see them directly in drawing bom.
Add your answer to: "How can we add numbers to sub-assemblies in CATIA to see them in balloons and bom list automatically in drawing?"
