how could we open foodprocessor.slddrw file in soildwoks 2013.but system shows file version is old
actually i open foodprocessor.slddrw file in soildworks but soildwoks 2013 shows error file version is plz tell me sir how to use this file
If it says "older version file" and the save button has a yellow warning triangle, it means that you've opened up a drawing/part that was last saved in an earlier version of Solidworks.
All you have to do is click save and it will convert it to the version of Solidworks you are running.
If you do this, it will no longer be able to be opened by earlier versions of solidworks, so if you need to maintain that capability you'll need to first copy it elsewhere for safe keeping.
Comments 2
