How do cut and contour in Rhino
Cut a contour program Rhinoceros create very easily. In the sidebar under Project icon on the desktop, see the Section and Contour (image.1) These functions can also be found at the top of the Tools folder of the curve, but this is somewhat tedious.
Function contours can be found right next to the cut on the left side. Contours to "dissected" the component on several consecutive sections. However, you must advance through the line to set the start and end sections, including the distance of each contour. At the beginning of the video is used in addition to cuts and contours also scale to which we are a part of the diminished 1:100
