How do I change the coordinate location of an STL file in Pro/E 4?
Hello guys, very green to Pro/E. Used almost every other CAD program out there! I have a job that requires me to take scan data and locate it to a certain point. The scan data is in STL format. I am sure the answer is simple, and would appreciate someone answering! Thanks,
Jeremy
Try assembling the STL file in assembly with shifted coordinate & recreate STL again.
