How do I change the lamp alignment angle?
Hi guys,
Attached is a lamp model in solidworks. I wanted to change the angle of the top part (curve)of the lamp to 45 degrees and also make the top head follow it. I am not able to do it so far.
Thanks.
Edit the sketch for the center-line of the sweep. Remove the vertical relation from the construction line. This should allow you to change the angle.
Then edit the sketch for the lamp head and remove all vertical and horizontal relations. Replace them with perpendicular and parallel ones.
