Missing feed
How do I create a scribe line around a piece of sheet metal?
By Kanaiya on 05 Jun 10:39 1 answer 0 comments
How do I create a scribe line around a piece of sheet metal which will show the machinists where to cut it.
I've tried the wrap feature, but it doesn't allow a 3d sketch to work and also tried to project the 3D sketch onto the mould I've created using the splitline. But this didnt work due to intersection of the sketch.
1 answer
  • A D
    A D over 3 years ago
    It were interesting to see the drawing of this piece, I'm afraid that you try to do something that's not necessary. If you want to show something to the machinist should be enough the simple drawing and the flat pattern (if you have the appropriate k-value).
    Try to upload a PDF- drawing with a few explanations on it.
Add your answer to: "How do I create a scribe line around a piece of sheet metal?"
