How do I create rib on a cylinder?
I tried creating a rib on a cylinder by drawing a triangle and then extruding it. But the result is as shown in attached picture. The vertical surface of the rib should be curved and attached to the cylinder. But I am not getting it right.
Hi, Anand
Try first to extend your triangle in the cylinder to have a good blend of the two features. Then you can subtract what ever remains from the triangle which sits on the top face of the cylinder... As a result you will have this rib touching fully your main body.
I hope to find this helpful...
