How do I cut only selected features? (Solid Edge ST10)
Is there a way to make use the cut-command (in .par-file, ordered mode) only through selected features? I want to: make a sketch > use solids (cut) > select which features the command should cut. Or is there another command to use in this scenario? I have tried delete faces but in this case it wont heal properly.
Hi Jimmy,
as far as I know that goes only in the asm.
Greeting Christoph
