How do I design a crown?
I was making a crown similar to Burger King's crown and got stuck midway. I do not have much experience with 3D sketches, please help
PS- please see attached jpeg
First make the cylinder as you had. Then in the midplane sketch a triangle and extrude cut all the way. Then use the array command and make the crown. No need for a 3d sketch.
Thank you for your quick response. The only problem is Burger King crown is not symmetrical; see attached
What about treating as a sheet metal part?
Perhaps the work flow could be: Create the cylinder, split it to create a flat pattern, Sketch and cut out on the flat pattern, go back to the folded model.
It might work, but I'm not at my workstation to try.
Comments 2
