How do I get a spring to stretch in a Solid Works 2011 assembly ?
When I add a spring to an assembly it locks it solid. Is it possible to get the spring to stretch so the assembly can move ?
Is there an example ( like a coil over shock absorber ) in the library I can upload to study ?
I have a flexible spring in the library that will work. Just rebuild after you move the part.
I want lern space block on the solid work
