How do I reference a thin feature sweep thickness, or shell thickness in a design table?
I've only been able to suppress or unsuppress the state of the thin feature of the sweep, or suppress the shell feature. I would like to be able to use the design table, but should this be a derived configuration, of each part from the table?
I would like to make a part file, that matches the suppliers available bends including the wall thickness.
If someone could point me in the right direction that would be great. Thanks
There are a number of different ways to do this, If it's a new part, create 2 configurations alter every variable in one of the configurations. Then insert a design table with auto-create switched on and all the variables will automatically populate the table. Or if you select the dimension in the graphics window, the demension name will appear in your property manager. In this case D1@Sweep-Thin1 you can just add a column with this dimension name to your table.
