How do I work continuously with a command in the sketcher? (Beginner)
I use CATIA V5 and I have a problem with the sketcher. When I click say the line command, I can draw only one segment of line at a time. I have to click the line button again and again to continue sketching. I've seen tutorials on YouTube where they draw continuously without having to repeatedly click on the desired command. How do I set it that way?
double click on the line command icon and now its ready to use continuously , the line command will remain active . use escape key to end the command in sketch.
if the line command is clicked only once the line command closes after the line is sketched .
also you can try profile command which is continuous by default ,you can give the desired dimensions later after making a rough sketch
Comments 2
