how do we setup vray rendering
rendering setup?
see the attached files you can understand how to setup vray lighting and rendering settings
The setup of the VRay engine renderer is not so important like materials and lights settings.
You can have beautiful renderings with standard setup rendering with correctly illumination and material set up, but you can not have the same results only going to set Vray for rendering best.
So the standard settings are quite good for a beginner
