how i can change all dimension of my part three times bigger?
Use scale (Insert>>Feautres>>Scale) command in case of part... In case of assembly you can't directly but editing each part and then scaling them.
hope it helps.
You can save an assembly as a part file then scale that part in one operation. Be sure to select 'Origin' from the 'Scale about' drop-down.
The attached Word tutorial shows how to make a configuration that will triple your dimensions
go to mold tools u will find scale tool there...
use the tool....put from origin...put 3 in scale thats all buddy.
