how i can run downloaded models in my solid works ?
when i want open a model by my solid works ,solidworks gives me a massage such this " Cannot open H:\...................(model name).SLDPRT. Future Version " and id clike " OK " and model automatically exits?
Older versions of solidworks cannot open newer versions files, you can downloads neutral format such as a .STEP (If one is not provided you can ask) Then open it with solidworks it will be imported geometry though and none of the mates will transfer.
you must upgrade your solidworks to newer version
newer version solid model cannot open in older version in solidworks or in any other software so if like to open it than open it in updated version
otherwise convert it inti stp or in igs file and then open
if you like it hit it worked button
