how join two cowl flaps with a joint or hinge in catia
how to join the cowl with a joint or either we need to design seperately and assemble or designing that joint on cowl?This cowl joint will be joining on one side and other side is left to open.after joining this we need to give simulation for that instaed of engine we need to assume a rod.with that rod i join the cowl applying a that by that piston if we give simulation the cowl starts simulation i.e open and close pattern.
Hi friend good morning, I was trying to open, your link, but the link its break, could you please assembly in your computer, and send us a picture, explain us with your issue, to help you.
Best Regards,
