how separate an assembly in solidedge?
hi guys i receive many assembly format .step and i need to separate pieces to inspect one by one how you make it ?
i know it how is it in solidworks any help thanks friends
If you know how to do it in SolidWorks, you shouldn't have any problems with SolidEdge...
Import the STEP file, delete all the parts except one, then save it as a part file.
Redo the same steps with every part and you'll have all the parts as part files.
If SolidEdge works anything like NX, you can 'probably' select each component and export them out.
