How to add a motion constraint to a bearing?
I have made a bearing and I would like to add a motion constraint to the balls and housing. First I click on the "Constraint" button, then I choose "Rotation-Translation" motion type. The first selection is the inner side of the housing, and the second selection would be the ball, but I can not select the ball.
Is there a way to make it work?
At Dynamic Simulation add 3D contact joint. Make sure You have enough degrees of freedom with ball.
Comments 5
