Missing feed
How to add a translational rotational constraint in Inventor?
By e17f7554 on 07 Dec 19:58 2 answers 6077 views 2 comments
How do you add a translational rotational constraint for a screw jack mechanism? I need to add a constraint as for which I rotate the tommy bar, the screw will translate in the nut.
  • Shuchon
    Shuchon over 3 years ago
    Its pretty easy thing to do in autodesk inventor assembly environment.
    Within assembly environment,
    >>>Click on constraint
    >>>Then Click on motion tab
    >>>Select Rotation-Translation
    >>>Then select parts you want to move/translate
    >>>Type in the translational distance for one rotation
    Yes, it that easy!!
  • Shuchon
    take a look at this. Are you looking for this?
Add your answer to: "How to add a translational rotational constraint in Inventor?"
