how to add a under cabinet light in Solid Works 2011
Is there a way to add a lights as a under cabinet light in SW2011. Please see the sample image
I assume you just want the lights for rendering purposes? You'll need to add some sort of geometry for the lights, or alternatively you can create a split line on the bottom of the cabinets so you can control the appearance of that face.
You'll want to then go into the illumination controls for the face or feature that your create for the lights. Turn up the luminous intensity (you'll probably have to render out several values to see what works the best)
-Rohit
<a href="http://solidwize.com" onclick="window.open(this.href); return false;">
Online SolidWorks Training: Solidwize</a>
