How to add assembly to assembly in a way it moves?
Hello. How can i make a new assembly, and in my new assembly how i put another assembly already made, but in a way that she moves? when i open one assembly inside another, the seconde assembly is static. It doenst have movements. thanks
Pedro, after you insert the assembly right click on its name in the feature manager and select Component Properties. Under "Solve as" select Flexible. This will allow the assembly to move as it did before you inserted it.
