How to add Bilateral tolerance in SolidWorks CAD interface.
In Solidworks drafting interface one could easily add all sorts of tolerance (Limit/Unilateral/Bilateral etc). Is this possible if I could add those during modeling rather than adding in Hole- Call Outs in drafting.
Hello Naseeruddinkhan, yes you can do that. It is EXACTLY the same way you do when you add the dimension in the drawing. When you dimension the sketch do bilateral and when you import the drawing view make sure you have Import Annotations checked with Design Annotations. Hope this helps!
