How to add different size of weldment using one sketch?
Hi all,
I wont to add 20*20mm square tube and 30*30mm square tube in weldments using same sketch. how can it would be done?
Draw the sketch.
In Weldments, insert a 'Structural Member' for the 20x20 tube selecting the appropriate lines. Complete the command
Start the 'Structural Member' command again and select the 30x30 tube. Then select the selecting the appropriate lines in the sketch for these.
