how to add material in solidworks and one more doubt
I have to calculate the weight of the component so I need to apply the correct material to the correct component.my problem is I need mildsteel material in solidworks 2010 but there is nothing naming like mild steel.so I searched in web they specified that plain steel is mild steel so I used this plain steel.but the density value of the mild steel is 7850,but this plain steel showing 7800kg/m'3..zo please help me how to xo this operation in solidworks software
You need to create a custom material.
In the material dialog box, copy and paste an existing material into 'Custom Materials'.
Then edit the values as required.
