how to add rotary engine mechanism in pro wildefire 5.0
i had a project to make a rotary engine in pro engineer but i was unable to make it move properly in the assembly.
Theres a ptc tutorial using a fuell engine powered drill, if you open that and go to mechanis, you can let the piston rotate in the cylinder for a set time. You can also find out how its set up.
