How to analyse Pro Engineer component in Ansys 10.0 welding property?
Comments 2
Good morning,
You can do this using multiple ways (depends on your experience in work with ANSYS to know their oldest and newest capabilities). From my point of view, first way is to used ¨spot weld¨ conection (existing in WB as in ANSYS MAPDL too), second way is to used 3D model or 2Dmodel (depends on your object of study) simplified and after that create an submodel with all details and run the solution. More precise study can be done if you will used first an simplified model to extract nodal force which acts on weld and then make an study static and dynamic (LS-Dyna) study.
Keep in touch.
Best regards.
u can weld through following step in workbench
There are one "WELD" option in geometry. there u can create weld
Answered with a tutorial: https://grabcad.com/tutorials/how-to-analyse-pro-engineer-component-in-ansys-10-0-welding-property
