how to analyze a turbine
to be analyzed in ansys
when you open ansys chose fluid flow CFX and drag it out on to the project schematic.Then open the geometry tab and if you have the CAD model already saved as a STEP or IGES file go to the top left of the screen and click on the file tab and go down to Import external geometry. Import the file and click generate.close the tab and click on the mesh and create a mesh. Finally click on the setup tab and follow the wizard. analyse and get your results.
Hope this helped
Yohann
