How to animate constraints for a camshaft
Hi, i would like to learn how to animate a camshaft constrains in catia V5.
In some of the 3D programs you just need to add tangent constraints between 2 parts but this is not the case in CatiaV5.
What i want to achieve is to move the cam itself so that the vertical shaft slides along the shape of my cam.
Please help and make a short and easy (or long and not so complicated) step by step tutorial how to animate constraints for a camshaft as shown on this screenshot i attached.
Also adding my files for this learning project. Maybe it will help somebody.
Thank you for your answer.
The goal is to animate it in DMU but i need first to know how to make those constraints in catproduct file. There is no tangency constraints in catia so i do not know how to do it and i need a little bit of help.
One more try with my CatiaV5R21 files ;)
Comments 2
Your attachments are showing the error while opening.
"DMU Kinematics" workbench in Catia is used to animate constraints by fixing a body and add some appropriate Degree if Freedom to joints.
still need some help so anybody know how to solve it?
@Ali Farnia
Added a batch conversion to v5r18 (i think... -.- some people say it will not work - and i only have v5r21)
DMU kinematic--> click the Assembly constraint conversion tool (below the anchor tool )--> then click the part ---> click new mechanism on the recently appeared dialog box-->click auto create mechanism-->then click mechanism on the specification tree--->command-->Enter the translation or rotational mechanism value on the command... before that check for degree of freedom should not be 0... after that a dialog box will appear as "the mechanism has been simulated".. now click the simulation player and click insert--> now play... for slower simulation select level 0.01
