How to break assembleys into seperate .prt?
have a assembley wish to producw drawing files from seperate parts
Open the part you want to make drawing of then...
select "File>>Make Drawing From Part"
As far as I know ..... Right click on the part and select "Save Part(in external file)"
Well I think you can't break an assembly in to separate parts. Although what you can actually do is break an assembly in to many subassemblies
To do that select parts that you want to group in, then right click and select "Form new sub assembly". All the procedure is illustrated in the image below:
Hope it helps
