How to Breakout a shaft in Catia V5R18?
I need to break out some key and hole on my shaft. I picked "do not cut in sections" in shaft properties, because I don't want to draw the whole shaft again (see the pictures). I make a profile, hit apply, regenerate, and nothing happens.
When I turn off the "do not cut" option in properties, my shaft has been cutted and the breakout appears with individual hatch. I must hide the shaft's hatch and redraw all lines.
What should I do?
Thank you for the help :)
