How to calculate scissor-lift of such kind?
Hello everybody!
So here is the lift for exapmle Scissor Lift
I need to know .. what is the exact force from the hydraulic cylinder and how did you calculate it. Thank you very much for your support
Is this a cylinder that already exists or is it a new type of cylinder design? If it exists already, you should be able to look up the force that it can put out from the manufacturer. You may have to give them a call and they could look it up for you also.
