how to calculate weight in auto cad
means the any draw part in the auto cad how to calculate weight
Comments 2
Hello Sayaji, you can use the "massprop" command and then select the solid of which you would like to know the weight.
You will then get a list of data from this object, one of which is the volume, you can easily use the volume to calculate the weight.
in auto-cad go to tools bar than go to inquiry click the right hand side button and then go to the area and then multiply the material density.
Hi! You can install GeomProps ARX-plugin and set scale factor to get Mass in the column of Volume.
Years ago i wrote an instruction about it, but it was in Russian language. I suppose that Google Translate will help you to read it: http://energokot.blogspot.com/2011/03/autocad.html
