How to change the default plane position in a finished assembly
Hello, so the problem is, that I did my assembly in a strange plane position (as seen on pictures), and now I have problems when I'm trying to do the technical drawing. I would like to know how to repair this.
Any parts that have a (f) in the tree, right click on them and then select 'Float' from the menu.
Then apply mates between the main part and the planes in the assembly.
(I'm assuming this is SolidWorks)
thanks, I was facing the same problem and saved me as well.
