How to change the "ground" of the rendering option in catiav5 r19?
i downloaded the model of supercarbody challenge and after making the car, when i render it, the "ground" in rendering shows towards the side of the car instead of under the car
If you are using the "photo studio easy tools" you can drag an d drop the bottom up and down, so you can ajust the right level.
greetings
PS: If you are using "photo studio" workbench it is the same.
Comments 3
