How to convert a single model with different surfaces into a single solid in Solid Works ?
I wish to simulate the Glider Models that are available in your esteemed website in CFD. However, I find it impossible to simulate them as they are in different surfaces and to work in CFD the model should be as 1 Part/Body and a single solid.
Can you please help me out with this either by helping me convert one of the Glider say DG 1000 into one single solid and also advice me on how I can do that using Solid Works software.
It would really great if you could help me with this.
Thanks a lot !
Comments 2
You just need to create a new solid like an estrusion an then change the surface ... There is the option in the surface window is kind of easy..
