How to convert a .step file into a solid object in autocad
Have a .step file I need converted into a solid in autocad 2012. Have no clue how to do it, seems like it should be the simplest task.
Thanks!
You can use Autodesk Inventor Fusion for converting Step file to DWG file!!!!
Step 1:- Open Autodesk Inventor Fusion and Open the Step File which you want to convert
Step 2:-Now press Save Button
Step 3:-And give a name for your file and the Save as type should be dwg format and finally hit Save option
Step 4:- Launch Autocad and Open your converted file....
Answered with a tutorial: https://grabcad.com/tutorials/how-to-convert-a-step-file-into-a-solid-object-in-autocad
