How to convert an assembly into one solid model (single body) IN cATIA?
I want to convert a assembly consisting of more than 100 of parts into a single body what is the procedure that i have to follow. Please help me in this problem
Open your assembly and select it in the tree.
Then, in the menu, select:
Tools -> Generate CATPart from Product...
Then you can choose if you want to merge all the bodies in to one body or have a multi body part.
Open your assembly and just double click one of your assembled files and then save it you will have one part product.
