How to convert step to fbx?
I found a perfect model on here for a project but I need to import it into Unity3d. How can I convert it into .fbx?
It looks like Unity will import OBJ files, would that format work for you?
I don't work with OBJ files often, so I don't know if this is a perfect method to translate files, but Keyshot will export STL and OBJ files.
Keyshot also opens many file types, so Step -> OBJ should not be a problem.
OBJ and associated MTL file attached. Let us know if it works.
yes that is fine as well. but how to get .obj from a .step?
In my original reply, you may notice the "Download" button. It has the model saved in the OBJ format.
If you wish to convert the file from STEP -> OBJ on your own, then Keyshot seems to work fine as a converter, but try to open the attached file and test it.
