How to convert technical drawing from Rhinocerros to AutoCad well?
Hello all..
i have a problem when i converted technical drawing from Rhinocerros to AutoCad,there is be a bad curve. each curve becomes not fused so that when I give the size markings on the object, it was be not precision.
Please help me.
Thanks before :)
In Rhino convert your drawing to 2D first and then export as DWG, if this is what you have already done, then either Rhino's or AutoCADs support forums would be the place to go
