how to convert to sheet metal complicated body
Hello GC community I struggle to convert one complicated body to sheet metal work with SOLIDWORKS 2017 I attaching the file please if someone know how to do it to help me by explaining what I need to do.
Thank you in advance.
I don't think that qualifies as a simple sheet metal part. There are a few areas that look like a more complex stamping operation formed the shape by deforming the metal. It was also likely made in stages by first die cutting, then stamping, then bending.
I doubt SOLIDWORKS will see this as a sheet metal part. There are some stamping plugins for the software, but I have never used them.
As a last resort, it might be worth trying to split the part up into smaller pieces and see if smaller portions of the model can be flattened.
This primary bend has two radii. I don’t know how a sheet metal part can be bent into two different radii (in software) in a single bend operation.
