Missing feed
How to create a bent tube?
By Andrei Lucian on 12 Mar 18:42 1 answer 871 views 0 comments
I need a tube to be connected to a larger base without loss of pressure. I have tried with GSD but can`t find a good fit.
Added images
Square
1 answer
  • MASA
    MASA almost 4 years ago
    you can use intersection command in GSD or edge fillet in part design to create an interface between two sub parts.
Add your answer to: "How to create a bent tube?"
