how to create a gear??
include only 7 steps
I usually go to the toolbox and use one of the gears that come with Solid Works.
thats not exactly correct you have to figure out the involute curves and you need some information on the gear Dedenum circle addendum circle base circle and pitch circle then you need to know the number of teeth
Comments 5
