HOW TO CREATE A TAPPED HOLE USING RADIAL PLACEMENT IN CREO ELEMENTS??
HI GUYS I AM FACING PROBLEMS IN CREATING A TAPPED HOLE.I ALWAYS PUT IN THE CORRECT VALUES OF THE TAP AND THE HOLE SIZE(IN MY CASE ITS 2-56) BUT STILL CREO GIVES ME ERROR.SO IF SOMEONE WOULD TELL ME THE PROCEDURE OF CREATING THE TAPPED HOLE I MIGHT FIND OUT WHAT HAS BEEN GOING WRONG WITH MY INPUTS.IF POSSIBLE PLEASE POST AN EXAMPLE WITH IMAGES
