MASA
how to Create cross sections of a solid body in catia?
Question by MASA
i have a solid body in catia. i want to make several cross sections of this body. later on i would use these cross sections for a detailed structural design.
bayou
Answered on 9 Nov, 2013 12:35 PM
Hi
You can put your body in an assembly , and using a plane you cut the body with SECTIONING Command. using the option EXPORT AS in the result tab., you can have your section as a Sketch.
