How to create realistic water islussion
Hello ... i m going to create rendering of a ship in keyshot 4 and i want to put it into water ... do u have tips and trics how to make water realistic as much as its possible ? and airspace ? Thank u
Please look into my projects. There is one that is called experiments with water. It my help you get a good start.
Kamyar
Ondrej,
Download the textures and experiment. Sowing realistic water and waves is very limited if you use mechanical engineering software.
Comments 2
The light source is the "environment". assign "liquid" for your water. Also you must increase the size of your environment. If the environment is a typical room, 4x5 meter, and your water is 100 or 1000 meter wide, the little room and its lights can't show anything.
