How to create solid body in between 2 surfaces?
How to create a body in between 2 surfaces highlighted in yellow in the file attached? In this case, the 2 surfaces are part of 2 turbine blades stacked together.
Hello,
maybe u can first create a multi section using surfeces projection then split using surface in part design
