How to create your own texture/add a pattern or design in a texture in Soildworks?
By Mary Grace Salvador on 21 Nov 08:15 3 answers 579 views 0 comments
I need a texture (specifically glass) that has snowflake patterns/design on it. Is it possible to add a 'pattern' to an already available texture? If yes, how can I do this?
  • Olive Hudson
    Olive Hudson about 2 months ago
    The one conceivable course to this described by http://buyessays.cheap/ is open the SW in Modo 401 and make a Displacement Map (in view of picture of surface) - however keeping in mind the end goal to get something of value, the determination would be must be incrediblity high also the record size and peformance would be out the window.
Add your answer to: "How to create your own texture/add a pattern or design in a texture in Soildworks?"
