how to crop revit elevation basement after ground floor
revit 2012 elevation
control crop views in view control toolbar
Ina nutshell, just use the extents group from your properties palette. Make sure that "Crop View" is turned on to enable and "Crop Region Visible" is checked to control the crop region. You can also apply horizontal/vertical view breaks to split up the crop region as well after you have it selected.
