How to cut a margin relief in Creo Parametric?
I have a drill bit with a variable pitch and I cut the flute using the Sweep tool and two guide curves. But now I need to cut a relief that runs along that flute and it widens as it goes down the spiral (should take up about an equal amount of the circumference as the land). I'm pretty stumped so I hope you all can help me. Thanks!
