Missing feed
How to cut with sufrace?
By Mihai Barbalata on 08 Apr 17:04 1 answer 491 views 0 comments
How to put a part in another part?
1 answer
  • Brad Brown
    Brad Brown 4 months ago
    Offset internal surface with 0mm offset.
    Pattern the lattice structure to fill the area.
    Use the offset surface to cut the lattice structure (surface cut)
    Combine bodies to end up with one part
Add your answer to: "How to cut with sufrace?"
